Engine/Transmission (1998.5 - 2002) locker for Dana 80 rear-end
Engine/Transmission (1994 - 1998) Next Bomb?
Engine/Transmission (1998.5 - 2002) Injector inspection question
anyone know of a manufacturer that has a replacement locker for a dana 80 with 3. 55s?
the clutches are completely burnt out and i dont want to waste money rebuilding the stocker.
my local mechanic buddy and 4X4 guru searched high & low for a detroit trutrac (or the equivelant), the best option he found was to change to 4. 10s (i dont want that , or the expense of doing the front one also)
suggestions?
i have checked with both detroit, and arb suppliers, i also looked at their online application guides. anything listed for dana 80 is shown as 4. 10 gears or higher :(
I thought the D70 used a single carrier from 3. 42 up to somewhere in the 6. something range??? The D80 is very similar... it doesn't have carrier breakes like a D60.
steved
I just looked on ARBs list, Dana 80 35 and 37 splines 3. 73 gears and down. RD80 and RD91.
3. 55 would be in the "3. 73 and down" category.
Give Randy's ring and pinion a call tomorrow... they'll help you out. ringandpinion.com is their website I think.
Powr Lok
I have the open rear 3. 55 and was looking for something as well
The only thing I could find was the ARB
However, Randys Ring and Pinion or Reider racing said they could use a Dana 70 unit, then drill and tap the ring gear bolt to a Dana 80 spec.
If I put something in, I was thinkin get a Dana 70 Powr Lok.
You have to buy the Detroit for a 70 "HD". Drill the holes from 1/2 to 9/16, it goes right in.
I have the Eaton Electric locker up front, works nice.
JIm, you gonna play this year?
http://www.nationaldrivetrain.com/shopsite_sc/store/html/page23.html
DETROIT LOCKER DANA 80 DODGE - 35 SPLINE AXELS ALL RATIOS
225SL131A
DETROIT LOCKER DANA 80 - 37 SPLINE AXELS ALL RATIOS
225SL105A
http://broncograveyard.com/bronco/i-31870_froogle.htm
D80 Detroit Locker Item # 31870 - New
The most durable locking differential for you axle available!
Full traction!
Our Price: $578. 00 (Shipping Weight: 45 lbs)
http://www.4x4wire.com/dodge/reviews/7080lockright/
http://www.completeoffroad.com/wsm/c-64_dana_80.html
http://www.flatlanderracing.com/detroitlockers.html
http://www.drivetrain.com/dana80.html
http://dodgeram.org/ki4cy/4x4/Lockrite_notes.htm
http://www.4x4groupbuy.com/store/ad...ana+80&osCsid=c2a831d056b51e5374d582a53363b74
