Lockers for pulling
Permatex "FormaGasket" stuff
Lots of guys I know around here are pulling with some sort of lockers in either the rearend or frontend and I was wondering if you all had any kind of suggestions as to what kind of locker you would recommend for pulling. However, I use the truck everyday to drive and pull trailers. Should I use a detroit locker or should I use an air locker. I know most people use air lockers in the front end so that is probably the way I would go there. Also if anyone has any good places to purchase these products any suggestions would be appreciated.
I would use the ARB air locker in the rear and the detroit in the front only if you are going to use 4wd while on loose dirt and never on asphalt otherwise the ARB front and rear would be great. The airlocker in the rear will be the same as an open differential while daily driving and towing which is nice. I bought mine through Randy's (who also installs them) 360-659-5259. I think summit racing also has a good price on them. Good luck.
I put a spool in the front and a detroit locker in the rear. Since 99% of the time I'm going straight when I'm in 4wd, and aftermarket axles in the rear.
