Locking gas cap on new 2022 3500
ERS issue?
pulling in 6th gear
I see no way to secure the diesel filler or the def filler. Lid does not lock with truck turned off.Maybe it locks when you don’t have the key fob by the truck. I will check it out. No it doesn’t lock how should I secure this what are you guys doing
Ok so fresh def. is it dated then how should I know
N
Walmart has a straight up manufactured date on it, whereas other brands use a Julian calendar you need your secret decoder ring to figure out when it was made. Basically if you find some on the shelf at Walmart it’s almost guaranteed fresh, they move it like hot cakes.
You are doing this to keep things out? The car wash from the dealer put water in the factory filler plug on my 2018... so yeah keep something over the filler. The door seal ain't that great.
If someone wants the fuel they will do other things like: punch a hole in the bottom of the tank.
Genos diesel cap came. Pretty nice. No water or dirt in the fuel. Or anything else for that matter. Save the instructions might take a time or two to get it right
