I'm going to take a 2500 mile trip in july Oo.
Just had an axle replaced (2 axle 5er) (That's another story). Thought I better check the brake wiring, the axle shop is a BIG truck axle / springs shop, not a wiring shop, they deal with 50 ton jacks not wire nuts.
They had "engineered" the wiring on the replaced axle, but I fuguered that would be the case. 300# BIG guys are good with semi axles, not with little wire nuts. However the manufacturer brake wiring left something to be desired.
Seems one of the magnet wires was a "little short" so they just twisted in a 2" "jumper". No wire nuts, no electrical tape, just a twisted in splice.
Ok so I went to HD and got what I needed and found that there are waterproof twist on connectors now. Apparently they are filled with a gel or paste of some kind and you twist them on and the twist connection is now weather proof.
I totally rewired mine and soldered all connections then screwed on the water proof connections on the soldered connections and zip tied everything down real well leaving a loop for axle movement. And yes I get a little anal, but the RV weighs 13k and I want ALL the brakes functioning correctly.
I just had the annual bearing repack done as well.
However, the point of the post is if YOU haven't visually checked your brake wiring in a while and ASSUME (makes an *** out of U and ME) all is well, might be time to "get out and get under" to make sure some "jumper" was not "needed" somewhere during the manufacturing process.
Bob Weis
Bob Weis
