Engine/Transmission (1998.5 - 2002) lookin for more power
im lookin to increase my hp a little more, where do i want to go from here?at442rw now would like to hit 500! help me out ... thanks see mods below
Something isn't right. You should be over 500hp with that setup. How much smoke do you have now?
There's a chance that just losing the Swampers would cause you to dyno 40-50hp higher! I bet you're making the power, it's just not showing up because of the heavy tires and such.
Of course, you could always go EDM (mach 5s) and pickup some power.
If you're running Pius' USB, then maybe just slip a Big Brother underneath it?
Why is it to weird to me to see a post like this coming from you, Cliff?
Justin
I have to agree with Justin. Something is not right. Too many performance boxes, and an argument is happening between them?
BD 5's, fueling box, and turbo should be at or over 500.
I agree with sticks and Hohn. Something isn't right. You should be ALOT quicker then 14. 1 in the 1/4 mile. I ran a 14. 07 a couple of weeks ago, and I have Mach 1. 5's.
Paul
As far as the tires hurting on the dyno, we have done numerous tire/wheel combos and HP has always been the same. TQ has moved within the rpm range slightly with the different tire combos though. Now the tirs will be hurting you on the track! I would be some 265's will yeild much better 1/4 mile times. I also think you may need more turbo to hit the 500 mark. I pretty much made 450 HP with DD supermentals, B-1, and a drag comp... ... .
You could also just add a shot of N02 and make over 650 HP easy!
Just my $. 02 worth
Doug
Are you sure you do not have a boost leek??
If you go into the Maryland section, I posted a video of your truck running at Cecil County. The smoke is heavy and never cleans up.
