Looking for a Cummins part number...
48 RE operation/personality question from an auto newbie
06 low power
... for the fitting that presses into the engine block at the bottom of the turbo oil return line. :confused:
Thanks in advance!
100 Proof
Have you ever tried Here you can sign up and put in your engine serial number and get a complete parts list. I can't remember my password so I can't get in right now but I check it later or you can sign up yourself
So the fitting presses in? No threads whatsoever?? If I am going to run the return line from my oil bypass system back into the block (I'm assuming this drips right down into the pan) at this location, I imagine I should probably purchase one of the press in fittings and then modify it to accept the return hose from my bypass filter, correct?
My bypass filter came with a large hose barb for use with 3/4" hose and I was under the impression that I could just thread it into the hole on the side of the block, once I removed what felt like (I couldn't really see down there) a freeze plug.
Any input on this? THANKS!!
Also, THANKS for listing that part number! I am going to check on it tomorrow.
Does anyone know if I'd have a chance of being able to drill through and tap the dummy plug that is already in the block????
It is a "frost or freeze" plug. You would be trying to tap the block and guess where the filings would go? It is a good place to run an oil drain as the oil will go right into the pan. Shadrach
