looking for a less expensive than a fass pusher pump setup
ETC engine purchase question
Edm Injectors For Cr ????
So what kind of options are out there, are they all like 600 bux or what, thought that seemed kinda spendy for just a small electric motor some aluminum billet and a couple of filters
Call Keith at Diesel Dynamics. They have one that works great in the $300 range. The kit comes with bigger lines too. Easy install and great instructions.
For folks who modify their trucks the stock lift pump will not flow enough fuel to keep up causing starvation at the cp3. The DD kit gets rid of the OEM unit, the banjo's at the filter and cp3 and has larger lines supplied by a new pusher mounted back by the tank.
XCumminsX
No, all it does is keep the fuel supply to the pressure pump at around 15 psi, the pressure pump is what feeds the injectors.
I like the helper pump from DD, easy install and a fair price.
It will not effect how rich your truck runs nor will you see a power increase. This increases the fuel supply to the cp3. It is aimed at bombers where the stock fuel supply is inadequate.
Check these guys out too, for filters. When my warranty is up I'm considering using one of their 2-micron filters:
Dahl fuel filters
Click on "Dahl filters" for a nice .pdf on the Dahl filters.
