Looking for boost module recommendations
DTT Valve Body issues or not?
2001.5 Fuel rate on injection pump
What boost module are you using? Looking for good and bad things to consider before laying out the cash. Thanks in advance.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S
Two sides to a boost module. You have the mechanical side (wastegate), and an electronic side which is a sensor in the block which reads boost.
The mechanical side is pretty basic regardless of who makes or sells it. All it does is blocks air/boost from activating the wastegate. Just a brass elbow with an adjustable set screw.
The electronic side of it all goes between the stock harness and boost sensor. It basicaly makes the ECM think you are only running 20# boost.
Edge products is very squared away. Their customer service is next to none. They can fix you up. Real good people to work with. Hope this answers your question.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
