Looking for Differential fuel presure gauge....
Need info on Gateglide(Geno's)
Pro Comp MX6 Shocks
I am not in a big hurry over this but I would appreciate any help that I can get in this. I am currently looking for a pressure gauge setup to display differential pressure readings between incoming and outgoing pressures from the fuel filter. This would be for a 3rd gen. Has anyone heard of doing this or done it themselves???
i don't know who makes it but theres that dual in one guages that u can get one that reads pressure/pressure that would work
A differential pressure gauge is an interesting idea, we used them in the Air Force to determine when refueling equipment needed a filter change. I suppose your thoughts are the same. For safety sake it would be a good idea to use 2 isolators with the above manual gauge so you could get it inside the cab.
So at WOT, what psi would you do a filter change?
