I'm mild in the BOMB department. I run RV275's, and an AFE drop in with an enlarged airbox opening, and a straight 3" exhaust. It runs great and really moves out for what it is.
I'll most likely be installing larger injectors this winter... for some reason the ones with 3 or III comes to mind. I dont plan on any electronic boxes such as the Edge. I want to make moderate power using only injectors.
Plus I'm also going to get a Rip 4" system with the Diamond Eye muffler. Want to tone this thing down just a bit.
I'm thinking more boost is in order but not to exceed 30psi at any time. Hopefully the turbo will last longer this way. I'll need a boost fooler for the MAP sensor and either an elbow or the TurboMaster. I'm really leaning towards the turbo master cause that will force me to remove the turbo so I can install a pyro sensor pre-turbo... without having to worry about metal shavings. I'll also go ahead and finally grab me a boost gauge while I'm at it. Those two gauges are a long time coming anyway.
I'm really hoping for adjustability on the boost levels and the TurboMaster is about the only thing out there that looks like it was made for fine tuning. Who makes the adjustable elbows if I decide to go that route? I thought it was TST but couldn't find it on their site. Thanks.
