Looking for these or Supplier
Ansa/Silverline Exhaust Questions
D
Buy a truck w 140K miles?
This Jumper is from a 98/02 factory Pump, I need 50 of them, the Company I was purchasing from is OUT OF Stock. If any knows of someone who has them Please PM or Post. I am also looking for the Manufacture of the terminal ends so we can modify them for our New Factory dual Kits.
I have look for Hours, thanks for the Help in advance. TC Diesel
I can try to identify the end components. Then you could make them up to get by. If so, get me close-ups of the ends and will see what we can figure out. If so will provide part numbers for you. Look like the same style terminals and ends that CATERPILLAR uses to me but a little too fuzzy to be sure.
You nailed it. That is exactly what Cat uses. If you have availability issues with those let me know. Can supply you with Freightliner or Cat numbers for you to find closer to home.
Just Pickup 30 of them from Ladd, $3. 80 each for just the connectors and Pins. Thanks for the Help. . I am still open for the complete Piece.
How long is the harness??? We are thinking that a Cummins 4025182 harness is what you need.
Just called my distributor and had him measure one for us. Overall length is 13 3/4", wire length alone is 11". Cummins has 205 in stock at the Ohio PDC. Cost should be about $20. 00 each if you have a friendly Cummins dealer out there somewhere. Maybe that is more than you currently pay, but would get you out of trouble.
Thats the one... I bought 5 From WBL Cummins $15. 00, So I will put these together and wait on ladd. . One Customer was PO when I told him it was $30. 00 for the dual Harness. . I have no problem with companies making Profits,but when you Want $15. 00 for that jumper and it has $4. 00 of cost... ... Thanks for the Help.
We make up a lot of our own now because of the price. We can repair a $300. 00 ECM harness a lot of times with $5. 00 worth of stuff. Once you identify the brand and series of the connectors it is pretty simple after that.
