Looky What I Found
Clutch Choices
Smarty Jr's on its way!! Do I need gauges???
This pic isn't as clear, but you can still see the breakage on the left side of the pic. Pic from driver's side so left is towards the front. The pieces don't fit together so there might be more broken teeth. I wasn't about to try to find them.
I changed the trans oil yesterday and decided to pull one of the fastcoolers off to clean it. I figured it wasn't cooling much with a full caking of oil/dirt. I saw the broken tooth and started feeling around. The pieces were all on the magnet, which is the little piece on the bottom of the second pic.
No signs of anything wrong other than what you see here. No weird shifting, no popping out of gear, no jumping, no nothing. If I hadn't pulled the cooler off I wouldn't know anything is wrong.
I'd almost tell you to button it up and drive it...
steved
Been there, doing that. I figure those pieces could have been there since the day after I installed the fastcoolers 3 years ago. Might as well run it and see what happens.
EDIT: 200 miles on truck this morning... same as before. Like you said, button 'er up and let 'er go.
