Loose Exhaust Manifold Bolt
Turns over several times before starting
Oil Analysis explanation?
I went to the dealer today with TSB in hand
aand yes just go to the parts department and they will order you the parts to perform the TSB with no problem
My parts were in LA and will be here in 5 days :)
Do your own mods :)
Finally went to the dreaded dealer today and he said that they would order the straps under warrantee but I would have to make an appointment to have them installed. After finding out that they only cost $4. 00 for the kit, I will buy them and install them myself. This way I can check the torque on a cold engine before I install them.
Don't mess with the bolts!
I replaced my POS manifold with the ATS manifold that was on display at May Maddness. It is 3-piece and I tell you, it is twice as heavy as the stock man. I have heard it is good for 1500 deg so no problem on heat.
I drive a 18-wheeler, and the engine is the N-14 Cummins and THIS is the kind if manifold that is on it!!
