Noticed fuel pressure dropping off every now and then a couple weeks ago so I baught a new transfer pump. Pressures used to be around 16psi @ idle and 11psi @ WOT. Now thry're at 14psi @ idle and 8 @ WOT. They drop to 9psi after running a while and comming to a stop. Before replacing I thought I'd replace overflow valve(cheaper). No difference. 3 days later fp dropped to 5psi. Replaced tp asap(already baught new vp44 30,000 miles ago from bad fuel pump). During this whole procedd I noticed my boost dropped from 34 to 27 without fuel box and from 46 to37 w/box. Fuel psi is now around 14psi @ idle and 9@wot. I have noticed more smoke(black) under acceleration wo box but power hasn"t seemed to change much. Also checked tps voltage @ wot and it's onlt 3. 5v. Shouldn"t it be around 5v? No codes in system. Any ideas needed. Thanks n paraniod, Ryan
Truck is a 99 3500, 5in exhaust, BD step 4's, powermax3, n Banks intake
