Well I had the ABS light come on the other day and I replace the rear ABS sensor today (58. 50) which mine is the one different one that hardly anyone uses. The other ABS sensor was 31. 00, well now the abs light is still on? Could my PCM be bad? I cant and dont know how to check for ABS codes, No one has been able to tell me. Does anyone know if the PCM is bad will the A/C and cruise still work? I am all ready out of 90 bucks so far and still have not found anything. I check all the fuses, adjusted the rear brakes, checked the plugs and wires, even unpluged the abs computer then the light went out. But when I plugged it back in it was right back on.
If I do the key on key off deal it shows 12345 12345 so I guess that is 5 5, it flashes 5 times each and then quits flashing. What does that mean?
I am disappointed and at aloss!
Please Help!
Please Help!
