Losing oil and going out the tailpipe
06 fuel leak
Exhaust noise possible fix
The oil consumption probably pretty much wiped out the pattern. Not wornign will also blank the pattern a lot. Do any of the others show a solid pattern?
With the miles you about have to check injector.
Like it has been mentioned look for new injectors, not remans. If he is wanting larger injectors the BMS +50 are new and of good quality. The BBi's are also supposed to be very very nice injectors, but are about +100hp so without UDC to dial tuning in they may run too hot.
If the pistons are damaged, and/or the cylinders have to be bored over I would go with the HO piston and upgrade the oil cooling ability. Look at the hp rating on the valve cover to determine if it's SO or HO.
