Hi: I have a '96 5 speed, 16 C. M. Turbo from Piers, and modified torgue plate, as well as a Transfer Flow aux. fuel tank. About 1 year ago the truck started to miss after starting when it sat overnight, and this was particularly noticeable if it sat on an incline with the nose up. Piers Henry suggested I have Transfer Flow check the switch over valve, to see if it might be the problem. I just finished taking the truck to Transfer Flow, they spent 4 hours pressure and vacuum testing all of the fittings from both tanks up to the fuel lift pump, and could find no leaks.
Does anyone have any ideas what else could be causing the problem? Incidently, after missing for the first 1/2 mile of driving, the problem clears up and it then runs fine.
BillGaines at Transfer Flow is also interested in finding out what the problem is, and they really treated me right on trying to resolve the problem. Thanks, Jack
