Engine/Transmission (1998.5 - 2002) loss of power at freeway speeds--
2nd Gen Non-Engine/Transmission Snow thrower for Dodge RAM?
Engine/Transmission (1994 - 1998) Broken Stud!!!
It turned out to be that blankety blank VP44. 2nd one in less than 2 years. I put a
FASS system on it a while back, and it felt like it cured it for a month or so. But my daughter was driving it the first time it acted up and it didn't act up again for me for at least a month or so. Soon after that is when I put the FASS on. Now the only lift pump this VP44 has had is a FASS. And it runs like a top now. After looking at some of these other threads about the module in the tank, I do believe that is next in line.
'99 QC 4x4 ATS transmission, tc, & commander edge ez, 4" exh. , afe. and FASS.
boost and pyro and mag hytec rear diff and transmission pan.
Did your truck just seem to drop back to just above idle? Like it was getting fuel just not enough? I just replaced my vp last April and now I'm having issues. When driving at 60ish it just drops out. If I let off to idle it comes right back. It used to ONLY do it when I was below a 1/4 tank of fuel but seems to be doing it more now. I still use a stock replacement of my LP. Was considering a FASS. I checked that by lp was working. I pulled the plug out and manually ran the lp (with i wire i rigged up) and got pleanty of fuel. Then this morning I had NO issue. I'm wondering if i just had the plug too loose and it was sucking in a bit of air.
Any info would be great. If this is the same problem.
