Hi all, I have been having some problems and I'm sure I can get some help here. . I've found that going to the dealer for a dose of frustration and then having to fix problems myself isn't working for me, go figure.
The problem started on my way to get the trans upgraded at DTT. I noticed that in high gear when I mashed the throttle the turbo would fluctuate, winding up and down while at full throttle. From my xmon the egt's were 1300 or so and the EGT limiter was set to 1450. The xmon was at 100% and did not show defueling. The EGT's are a little higher than usual and the truck doesn't have the power that I have grown used too?? Replaced the fuel filter and cleaned the air filter with no help. Put on a 5" exhaust because I kept blowing the back half off and the wife ran over it wrapping it around the axel? Still there. I am thinking pressure relief valve or injector. . I pulled the dip stick to check for diesel in oil but can't smell anything. I am running rotella T synthetic with Oil guard bypass.
Any help would be greatly appreciated.
Thanks in advance,
Bill
Thanks in advance,
Bill
