'01 2500, 4x4 diesel, auto, 85k miles used for towing and snowplowing
The truck shifted out of overdrive when towing up a hill, has not had overdrive since.
The wiring from the PCM to the trans control solenoid and on to the transmission shows good continuity.
The control voltage and the soleniod coil voltage is present at the relay socket.
relay has been replaced
The transmission shifts properly when the 3-4 shift solenoid is activated with an external voltage supply. (jumper harness)
Scanning through forums I notice that the trans fluid temp sensor was a
week link. I dont see one on this unit. At least not in the coolant line.
truck has no codes, i would appreciate any ideas.
thanks
thanks
