Just alittle something to add, Pay attention anyone who pulls a trailer! There are two "fuse panels" the first and most reconized being the fuse block, located in cab left hand side od dash, behind access panel. This block takes care of most "normal" electrical functions, radio, interior lights, lighter,ect. This should be your first place to look, if you have a malfunction. Then there is the PDC, or power disribution center, it is located under the hood, left hand side, between fire wall and battery. Inside this block is your relays, 3-4 normal type blade fuses, and FUSIBLE LINKS. These FUSIBLE LINKS requir a very specific type of fuse, they are not available at most parts stores. If you travel alot pulling a trailer, or use want to be prepared, please go to your dealer and get a couple of each type of these fuses. They control items like your trailer brake supply, trailer 12V supply, as well as other non-trailer related items, bottom line is you do not want to be on the road, and lose one of these! Any one haveing a sudden loss of brake controller power, this is where you look. I found out the hard way, went to pick-up a trailer and when it hooked up had a instant short when I went to check my lights before moving. The trailer had gotten it's power cord smashed and someone put it all back together wrong, my brake circiut was hooked to the ground terminal. It blow the large fusible link fuse, like it was suppose to, but left me with know brakes till I got to a dealer. They are about $2 each, and now I keep a few in the truck, and trailer as spares. Better safe then sorry.
