Low Beams-sometimes!
barring tool? where and how much?
diesel fuel addative
My low beam headlights won't work when steering wheel is tilted all the way down. High beams work with wheel in any position. I suspect a broken wire in the colum.
Just thought I would ask if anyone has had this problem before I start ripping and tearing.
Thanks Andy
Have seen this problem on several trucks all I ran across had a wire pulled out of the plug on the Multi Position Switch (turn, dimmer, wiper) The wires going to it are tight. I was able to pull a little slack and glue the terminal into the plug and each time it works great. Only special tools you will need are tamper resistance torx bits
