Just changed my filter with a Baldwin PF7977 and now when I turn up the Juice I have lower boost levels than on the stock setting. Full throttle on stock 37 psi, WFO level 3 28 psi 1K EGT didn't try any other level because I got a little spooked. Also I'm noticing a pos. injector rattle/slightly rough idle intermittently. I'll be heading to the dealer on Tuesday for a look. Any ideas ( bad FCA, bad injector/s, lift pump, CP3). Truck has been running fine and was getting ready to put in an Airdog 150(little late now). If it's injectors I may be going the F1 Flux 1 route. I'm thinking the filter change was coincidental since I've been noticing a bit more smoke at idle for a while and a intermittent rough idle I chalked up to carbon deposits. I know the only sure thing is to take it in but I'm looking for some ideas first. Took the last dealer 4 visits and me stranded on the roadside to find a bad FCA and rail relief valve at 50K, I won't be going back there. Thanks for the input and sorry for the rant.
