There has to be someone out there who had this issue and resolved it or atleast has some good ideas. I will pressure test the system tomorrow and post results.
So far i changed the map sensor, fuel pressure releif valve, turbo, pinched the WG hose on the new turbo, and all new heavy duty boots ands clamps on all intercooler piping and turbo. I cannot boost past 30ish. I have Smarty stacked with MP8 and those are ruled out as i tried Edge, and Bullydog getting the same results.
Maybe there is a hairline crack in the cfm, or the cooler?
It acts like when there is an intake gasket leak on a gasser.
I have a new turbo which can boost 50 psi efficiently all day and i can't even use it. This SUKS.
I can hook up a drive pressure gauge to it tomorrow but i'm not sure if that will give much useful info in this case.
Please throw some ideas at me no matter how left field you think they may be. I'm desperate
