Engine/Transmission (1998.5 - 2002) low fuel pressure with fass system
Sounds right to me. The stock lp's kick out about 3-10 lbs then bleed off, the ecm only gives it enough power to start it to run to bring up the pressure so you can start it. If it went to 17 lbs and stayed there, it would not start as easy.
Dirk
