low pressure fuel lines
pump timing
Transmission Case Vent Hose Location
Does any one know were I can get them? Mainly the one inbetween the filter and the injection pump. Or, better yet can I make my own? What thread is in the pump, standard pipe? metric pipe? compresion? Also were could i get a banjo fitting to make my own line? Any help would be great.
What did ya do to yours? Break it while trying to bend it to get more throttle travel? Might try heating it up, off the truck, before trying to bend it. I might be able to get a part number for you from one off my 89 non-intercooled truck. I swapped them out when I switched pumps cause the previous must of already heated/bent his cause it was bent out of the way of the throttle lever. On the nonIC'd line, which is the same thread size, it was in the way big time.
Im doing a wvo conversion and I want to tap in to the line there. I want the WVO to have its own pump and filter. So the only place to tap into it would be that line. If what I have planed works it should actually work out realy well. So if some one had one with good ends that would help me out a ton. Dont care to much how the middle section is cause it will be cut out any ways. Thanks for the help.
