Anyone know where to find one? Can’t find one with this pattern new or used. Have tried folks parting trucks on CL, have contacted wrecking yards on car-part, no luck.
Anyone know where I can find one new or used?
Thanks!
I'm not sure if that knob is from a GM product, Ford, or a dodge... I'm thinking Ford, but if it is from a GM, good luck!!!
Lots of junkyards have Ford trucks with manual transmissions. That said, The actual knob is a bit different for 1990's models. It is splined, instead of having threads, but the entire shifter can be used if you can figure out use a drill. Perhaps, the older Fords used threaded knobs??? FYI, a junkyard would probably just let you have the insert for free... Just be honest about it!!!
I actually have a shifter from a '96 Ford gasser in my '09 Dodge with a G-56. I hated the funky bend that makes one of the cup holders unusable.
From what I see there are 2 folks in common for these kind of things if you can get by with just the insert.
OMIX and Crown
Maybe reach out and see if they can reproduce a few for you. Never hurts to ask.
https://www.omix-ada.com/webforms/index/index/id/12/
https://www.crownautomotive.net/contact-us.html
Good luck with your search.
If you find an actual part number someone might be able to find more info.
Year, Make, Model, type of trans?
Someone might have something sitting out back in the weeds somewhere?
