Cee,
I would probably not upgrade the clutch at all but if you do my recommendation would be to use Southbend Clutch's mildest offering. Cummins and Dodge spent a lot of time and money determining the best compromise when they chose the Luk clutch disc and pressure plate. Any aftermarket product involves a different set of compromises. The higher the clutch rating the more difficult it will be to use. Stronger springs in the pressure plate and material offering increased friction in the clutch disc create clutches that engage abruptly. The factory Luk products served me very well. The secret to long life with a clutch is a skilled driver. If you already know and practice this method I apologize for writing it - never raise the engine rpm above idle when engaging the clutch from a stop. Gently engage the clutch and increase engine rpm only after the clutch is fully engaged.
I am not a believer in modifying HPCR engines with aftermarket turbochargers, air filters, or magic black boxes. Earlier 12 valve and 24 valve engines were a different situation. A modified engine gives up service life and may be subject to early catastrophic failure. Injectors in hpcr engines are already highly stressed and increasing performance further increases stress. An injector that fails often fails open, overfuels that cylinder, and melts the top out of the piston. Increasing power output creates new problems like excessive exhaust gas temps that shorten engine life, excessive boost that causes blown head gaskets, and more. To me accelerating faster when unloaded is simply not worth it.
The factory air box and filter is not a hindrance to power development until power output exceeds about 450 hp. PM Joe Donnelly and ask him. The OEM filter is as good as money can buy for protecting the engine from dust and grit while developing full rated hp. If you insist on increased air flow potential (not increased air flow) remove the factory filter and use an appropriately sized section of door screen. It won't do a thing for power output but will be cheaper to buy than an expensive aftermarket air intake and filter almost as well. Either way you'll be buying an engine sooner than if you leave it stock.
Your engine's rated hp and torque will do a completely satisfactory job of pulling your very heavy trailer. Increasing engine output to 650 hp and 1200 ft. lbs. of torque will not allow you to pull grades significantly faster but will allow climbing grades in higher gears including sixth overdrive. Doing this will guarantee transmission and driveline failure. Except for drag racing or impressing friends who are following you in Furds on long steep grades power mods are not very practical in a towing motor. My advice is leave it alone. Not too many years ago eighteen wheel OTR drivers were climbing the Rockies out west or in the Appalachians with less hp and torque. They were slower on the grades but always made it to their destinations and their engines lasted a long time.
Many will disagree with me but those who use their trucks primarily for heavy towing will be more likely to agree. It's your truck, your money, and your choice.
