Extreme1 said:The sulfur acts as a lubricant. Add a quality fuel additive that addresses the lower lube issue of the new Ultra Low Sulfur Fuel. You injector pump will thank you with a longer life.
SNOKING said:Additives = Snake Oil! (in most cases)
SNOKING
SNOKING said:Study up dude! 99 percent of people never use additives and do not have issues. Additives = Snake Oil! (in most cases)SNOKING
NoSeeUm said:Urch... .![]()
One of the good things that should make us happy, other than the better air we will breath, is that that ULSD now has a lubricity standard. In the past there has been no standard and the fuel got what ever came out of the pipe at the refinery.
So.....![]()
You can say it how you want, but to meet this standard the refiner will likely been adding some kind of "Snake Oil" to raise lubricity and meet the standards.
Jim
KKohagen said:This is exactly on point. The refiners (Big Oil) are now required to add lubricity compounds per the new standard. In the case of my employer they are adding it at the terminals. That way no contamination happens while using the pipelines, overall smaller amount of lube needed to be added to maintain the minimum level, which is aove the previous levels, at least in the diesel me made in the past and now.
We should see very little change except maybe less smoke. I work in a sulfur recovery unit and unless the sulfur is around 303ºF the lubricity does not change (get better) much. Below ~ 265ºF sulfur starts to solidify and the viscosity goes up. When the temp goes above ~ 330ºF the viscosity also goes up. Right around 303ºF is just right, of course I am talking about relatively pure sulfur, but I have yet to see any change in my truck running on the new ULSD.
Only thing I have noticed is my truck is around 10-15 dB quieter. Oo.
2broke2smoke said:... four pages of opinions ... not one solid fact at all ...
K5IP said:10 to 15 db quieter? db=10log p1/p2
10 db=10 times quieter
15 db=36 times quieter.
Joe G. said:Do a little math with the amount of additive in a bottle vs a tank of diesel. It's kind of hard to believe that the stuff in the bottle can have any affect at all.
