This has been going on for about a year in which the voltage reading at start up remains at 10V for about 30 seconds and then the voltage climbs up to 14.5V. I understand the grid voltage heaters turn on (drawing lots of amps and that is normal. However, in the past I don't recall the voltage dropping to a level where thee check engine light remained on. Since this is a 1999 Dodge 2500, does that sound like proper operation for the age of the truck (170K miles.)?
Thanks for any information you can share or if I should be looking at anything beside cleaning both battery connections, voltage drop test on cables to terminals, as well as the alternator and fuses,
Thank you for any help you can provide in this issue.
Ron
Ron
