2nd Gen Non-Engine/Transmission lower ball joints + caster
2nd Gen Non-Engine/Transmission Who Makes Air Ride Kits?
Engine/Transmission (1994 - 1998) Question About 12V Valve Cover(s)
I was adjusting the caster on my truck yesterday and noticed that my lower ball joints had an 1/8 " of up and down play in them is this normal for a truck with 40,000 miles? Also I adjusted my caster from the stock setting at 12:00 -12:30 to 10:30 11:00 the truck does drive a little better,will adjusting it further out make it track better,where I have it adjusted now is as far as I want to go before the trackbar hits the diff, cover. any suggestions thanks. Gregg
so It looks like mine are shot,does anyone know what the max is on the caster, as I stated before I am concerned with with a clearance issue with the differential cover and the trackbar ball joint.
