Lower Control Arm bolts
3rd gen steering box vs 2nd gen steering box
front bumper step
Getting ready to changer out the lower control arms and have read about the cam/ concentric bolts can be an issue removing. I have been searching for replacements, if I need to cut one or both does anyone have a source for these things?
Mine are suck solid. Got the nuts off but bolts and cam wont adjust , bolt must be rusted solid inside the bushing sleeve. I can see the rubber twisting when i try to adjust the cam with a breaker bar, but the bolt shafts inside the sleeve wont break loose.
Cant use heat or ya gonna damage the rubber bushing.
I assume many people end up buying all new control arms, aftermarket,
exactly... that's what I did. Went with Thuren.
My stock control arms were rusting through around the bushing.
Or factory, good quality and reasonably priced. I went OEM back then.
If I understand correctly the upper arms have nothing to do with front end alignment just support? My upper arms are good for now and will be replaced later.
