I have been hearing a popping when I go over bumps for a little while. It's not that noticable unless I have the windows down and expecially when there is something to reflect the sound back. Well, I finally got to looking for what the source of the noise might be. It turns out to be the lower mounting bolts for the shocks on the front end. The lower end of both shocks was loose so I decided to pull the bolt to see if there was any wear on the shock (RS9000). Boy was I suprised to see that the threads on the bolt had been worn down about half way by the shock beating on it for about 138,000 miles. If you ask me, it's a poor design. They are asking a standard bolt to take a shear load. That's a no-no in the mechanical design that I do and not a good practice in any arena. What should be in place is a shoulder bolt so that there is more meat to spread out the load and no sharp grooves for stress concentration.
Has anyone else had this problem? It looks like the steel bushing inside the end of the shock has marks from the threads rubbing, but is ok. The urethane seems fine too.
