LSD availability
Questions about fuel pressure readings
Is there a way to reach DC Engineers?
I am seeing a lot of 3. 54 w/LSD in the signatures. My dealer says that I can only get a LSD w/4. 10 in 2001??? Anybody know any different?
It's there you just have to push for it!
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
I know different. I have a 2001 HO with 3. 54 gears and LSD. (2500)
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
My brother just picked up his 2001. 5 H. O. 6 speed that was built in early January of '01. He was told the same story as you but he ordered the 3:54 LSD anyway. He got it installed and it works well. I have seen new trucks on the lot and it says they have it with the 3:54. GO FOR IT!!!! Chris #ad
With the torque that the Cummins makes the LSD is not optional, it is mandatory. Get it one way or the other. You will be miserable without it.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S Everything but leather NRA Member
I've had Cummins power With and Without LSD. Much happier WITH LSD! When shopping some dealers flatout told me you can't get it, but you can! I'll bet that if you told your dealership you'll get your truck from one that will order 3. 54LSD that they'll suddenly find a way to get it for you #ad
Vaughn
'01 QC SB 2wd, ETH/DEE, 3. 54 LSD #ad
I had heard the same thing and was worried when I ordered mine in late August. This dealer insisted that I could get it with the 3. 54 gears. Guess what, it's there. I remember seeing something that said that the 4. 10 gears could only be had with LSD. I think that is what all the confusion is about. Bottom line... Get your LSD and 3. 54 gears.
B I G O R A N G E AMBER-FIRE (BURNT ORANGE) / BRITE SILVER 2001(. 5), 2500, SLT, Q-CAB 4x4, SWB, AUTO, 3. 55, LSD, TOWING PACKAGE
ADD-ON'S: LINE-X, 1/4" STEEL LONGHORN HITCH COVER, WESTIN NERF BARS, YELLOW-TOP OPTIMAS
SandDeamon,
Don't believe the salesman! I'm sure you've figured from some of the earler responses that the LSD is available with 3:54's. I thought I'd pass on something my dealer (Jasper Jeep) told me when I ordered last summer. I can't remember all the details, but there was a discussion in one of the TDR forums on this subject around the time I ordered (8-26). When placing my order, I mentioned to my salesman that some folks on the TDR were being told LSD wasn't avaliable with the 3:54's; I told him that I was not going to take delivery of the truck with anything other than 3:54's with LSD, no open diff or 4:10's. He was well aware of the controversy, he said there was some glitch in DC's ordering system such that it didn't like orders specifying LSD with 3:54's. They knew the proper tricks to get the order processed. my truck came in on 10-10 complete with 3:54's and Limited slip.
Tell your dealer he's nuts. I ordered the 3:54 LSD from my dealer. He said no problem. And it came that way. Find a good truck dealer that knowes his product.
2001. 5 Silver 2500QC LB,4x4,5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Snow Plow Group, Clearance lights, most options, no leather. EGT,Boost,Westin side bars, Linex spray liner,(more to come)NRA Life Member. .
Time to find another dealier! One who actualy knows what he sells...
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
SandDemon:
Been down that road! RedRam1 is right on the money. There's a trick to ordering it that some dealers aren't aware of. I had the same problem. I finally found a Dodge rep. on the 800# (after 3 tries - even most of the reps didn't know how to do it) who knew how to do it. He got in touch with my dealer and told him how. The way I remember it is that when the LSD is ordered, it automatically goes in as a 4. 10. (Dodge thinks that everyone that wants a limited slip wants a 4. 10. ) After doing this, my dealer had to go back into the order and change it to a 3. 54. Then it took. I think he even had to have the district manager in Milwaukee do it. It's like an option within an option. If it's done the other way around, the LSD will be rejected due to the 3. 54. Just because your dealer doesn't know about this little trick doesn't mean he's a bad dealer. Mine is top notch - he just wasn't in on the "secret". Good luck!
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; Forest Green
I ran into the same problem.
You CAN GET 3:55LSD, my 2001. 5 ETH/DEE 2500 QC SWB 4x2 is one.
Seems the puter tries to reject it, but my inventory control dude manually over rode it and my order confirmed w/o a hitch.
Good Luck.
Max
