Very good post MountainMan1. That a lot of miles on your 05. Have you had any problems with it?
Good hearing from you Juan. How's life in GA. ?
On 3rd set of U-joints however the front ones have always been real good but replaced anyway. They don't bend much!
Rebuilt transmission because after makert shop installed a temp sensor in high pressure pipe and really messed it up. Blew out line, they used single tiny clamps, crimped the line when forcing in there sensor block, didn't tell me of course. But they assumed responsibility and had it rebuilt by Dodge who farmed it out and it only lasted about 10,000 when it began to slip. That is when I decided on the Sun Coast at 90,000 miles. Still shifts like when it was new. Besides that was around the time of Katrina and we were making big bucks from FEMA hauling their RV's!
Rear main crankshaft seal.
Both front wheel bearing hubs (4X4).
Ball joints. One front end alignment with that. My tire guy always wanted me not to have an alignment because of excellent wear patterns, but we had to with the front end work, naturally... but it seems as good again.
one cracked rocker arm caught at valve adjust at 150,000 miles... no adjust was necessary. Need to check them again soon.
Blew out plastic intercooler with Edge cranked up in a towing race up a mountain!
Replaced with upgrade then ATS Zero cooler... it works alot better.
Rebuilt rear end a few months ago. Check out Randy's Ring And Pinion in Everett, WA... outstanding work and unusual shop. Spotless! I arrived before they opened unannounced, they took me in right away, I was out by noon. Around $700. Checked rear axle bearing... like new.
One full set of brakes with new rotors, flush. No rebuild on Calipers. I try to set up trailer brakes tight but rarely use trailer controller except on long steep grades.
Front drive axle with cvj's for diff to transfer case. Three weeks ago.
Maybe shocks soon... maybe! But they seem okay.
Lots of headlights!!!
Two marker lights.
One license bulb.
I use Stanadyne from almost new religiously. I always measure one ounce to 4 gallons.
I tow at 58 mph and empty mostly 65 and sometimes 70.
