I’m planning on either Nitto Ridge Grapplers or Toyo Open Country AT3 tires on my stock 8” rims. The tire company says a 9” rim is needed. Does anyone have experience using a smaller than called for rim?
The managers have some discretion but company policy is to follow tire manufacturer guidelines. The 8" wheels are the minimum allowable for a 315 for some manufacturers. Mount those tires on a 8.5 or especially 9" wheel and you'll feel the increase in stability.Wow,
Discount tire mounted 315/75/17s on my stock 8" rims 03 Ram 2500 6 years ago... they just mounted new Nittos same size a couple weeks ago... 90K miles on the old ones, no uneven wear.
Cheers, Ron
Ron, I’m still stopped on the 90,000 miles before replacement! How did you manage that? I do appreciate your help as well as the help from others. Many thanks, Harry
"315/70R17 tires have a diameter of 34.4", a section width of 12.4", and a wheel diameter of 17". The circumference is 107.9" and they have 587 revolutions per mile. Generally they are approved to be mounted on 8-10.5" wide wheels for passenger tires and 8-11" for LT tires."
Discount tires web site does not match with the manufactures ratings. I check the rating for a LT305/70R18 from Toyo, BFG and General and they all have a rim range of 8.5 or 9 to 11. Discount tire web site says 7.5" to 10.5.According to Discount Tire, a 305 70R 18 WILL fit 8" rim and should work on OPs. Just have to search til you find something that fits.
Cheers, Ron
Different size tire than was asked about. Yes you can find other sizes that are rated for 8" rim but that wasn't the original question.
I normally put about 23,000 miles on my trucks annually. 4,000 to 6,000 of that is towing heavy here in the western states and the rest is back and forth empty to Mexico hunting. Without better tires I’m getting stuck on wet grass. It’s very aggravating. I’ve run Toyo Open Country ATII tires and liked them but would be happy with Nittos as well. After reviewing your replies I’m going shopping for a 295/70r18 tire. In the Toyo and Nitto tires, they have increased the ratings to 4,080 pounds. Both are a little taller and a little wider than the current Firestones. Hopefully everything should fit, not rub and provide decent wear. Many thanks for the assistance, Harry
