Lucas Synthetic Gear Oil
Ball Joints
Air Horn Experts
I've got a Mag-Hytec rear end cover on order from Geno's, and I would really like to try this stuff. It's 75-90 and I called Lucas and they said it would be rated at something around a GL-9 - they said it was bulletproof.
Does anyone know why I couldn't use this in my rear end?
Thanks for the help.
Here's a link.
I have always used the regular Lucas oil stabilizer in my front and rear ends. 100%---that stuff is at least 75-90.
I was eyeballin' the synthetic stuff though---more than likely I will use it when I get to the point that I have to change out the diffs.
Do you tow heavy? I believe a heavier lube is recommended for heavy towing. The only other thing may be the need for a friction modifier if you have the LSD.
