Lucerix Extended Towing Mirrors
does Superchip boost MPG?
C
Front end protectors
not quite.....
it appears to be a cut out for perhaps the future addition of a signal lite or something... . maybe an add-on accessory kit later i hope...
dont worry........
the toolman got me right after i finished the install... ... .
actually i like those super- duty mirrors... .
I just looked in my latest JC Whitney catalog, and I see they have a 15% discount for all orders over $200. That would put the electric/heated ones under $400. Oo. Oo.
Tim ... As promised ..... Tim
TNTWAY's Super sudty mirrors
<BR>
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff#ad
N. E. T. D. P
Toolman,how long did it take to install mirrors and wiring?Were you lucky enough to have the factory wires behind the door panel?
Ram Runners
Originally posted by BPINE
Hey there Buff I have a friend even closer the dabubba that will probably let you take a peak. Dave I think you are going to have to make it to one of the Ram Runners meetings, you can probably see one of every accessory know to man there!!! Curt you have mirriors too, how do I get a job where you work my sickly old Ram hardly has any fun. LOL
Blair... . I would really like to see the mirrors first hand. My McKesh's work great, I can see all the way down the sides of my trailer. Do the Lucerix extend out far enough to see the back corner of the trailer on both sides? Also I just bought a new Noah car cover, will the bigger mirrors fit in the pockets in the cover? If not... . do they fold flat against the door?
Whens the next Ram Runners meeting, I'm gonna have to try and make it. Gotta see what new toys I just have to have:D
Talk to ya soon
Dave
Actually it's TNTWAY's RIG but the install is simple Pop the panel three 12mm bolts? and clip the harnesses together and yer ... done
Cool, sounds like a good alternitive to the way I did mine, 'cept that I have both spot mirrors built in. Do those mirrors fold in? ie. in case you too close to a tree,findin' your good huntin' spot!:eek:
NO,NO, Tim,
I mean... ... ... ... . do they fold "IN",like if your going thruogh a car wash,not that ya' can,but if ya' could would they?
they fold......
forward... . towards the fenders..... flush too... ...
tim's right... . pop the panel, the connection is right there, three 10 mm nuts and you're there... ... really a fairly easy install.
mrs. tnt drove the beast tonite and loves 'em too
Re: they fold......
They fold forward?? do they also fold back towards the door? Seems to me that that would make the most sense!
They fold back, also. Just a tip..... make sure you put a paper towel in the door to cover the holes when you are removing the old and installing the new mirrors. Otherwise, you may drop a nut into the door through the holes in the mounting detent.
