John, if it has little 1" wide and about 3" long strips of material on the flywheel side of the disc (looks like evenly spaced segaments of material) mayby 10 to 12 of them and a regular facing on the other side, look at the pressure plate that goes with it. If it has a wire going around the fingers with weights hooked to them it is a product called Centerforce. As to the performance of it, it will hold better then a stock clutch.
I hope this helps.
Peter
