Luk clutch?
Cummins and Dodge tech CD
Oil filter half full or half empty
I have seen a clutch that a member had that I believe is a LUK, it had a puck system on one side and regular type lining on the other side. Does anyone know about this and is it succesful? and where to get one.
Tia
john
John, if it has little 1" wide and about 3" long strips of material on the flywheel side of the disc (looks like evenly spaced segaments of material) mayby 10 to 12 of them and a regular facing on the other side, look at the pressure plate that goes with it. If it has a wire going around the fingers with weights hooked to them it is a product called Centerforce. As to the performance of it, it will hold better then a stock clutch.
I hope this helps.
Peter
