I finally got around to installing a Luke's Link on my track bar this morning. I'm confident I got everything right - everything fit well and the adjustment from the poly spring to the cap threads seems fine, right at the 3/16" Luke's recommends. Everything went back together without problems, although my wife had to turn the steering wheel quite a bit to get the pin to line back up to the frame. Torque at both ends was set to spec from the maintenance manual, and I re-greased the link end before I reattached it and afterwards once the pin was torqued in.
Now I have a slight pull to the right and my steering wheel is off center a few degrees to the left. Have I done anything wrong? Could the track bar been so "off" that the near perfect alignment I had before simply compensated for that?
I have less than 65K on the truck and almost all off those miles were paved roadway. I'm putting on new tires in about four weeks and I wanted the track bar to be nice and tight. Any ideas? Thanks!
