Okay, turn off the calulator and put away your turbo maps for a sec, take a step back and look at the big picture.
Len's truck has enough fueling for about 350hp. He tows heavy. His observation is that his temps are too high for his comfort when pulling up long grades. The fact that he can hit 38psi, but he's only seeing 25psi on the pulls tells me that he's not at full throttle. The engine is probably only developing 200hp or less at that point, and is probably turning about 1800 rpm. He doesn't need full throttle, high rpm cooling. So forget the 350hp. It doesn't apply here.
Is the 'BG adequate for 200hp? Absolutely.
Would switching to a 12cm housing extract more energy from the exhaust stream compared to the 14cm? Yes.
More energy extracted from the exhaust gasses translates into more energy driving the compressor, which will result in more boost.
For the typical Dodge/Cummins application the 'BG is good to 40psi (per HTT). So any increase in boost from the 'BG, up to 40psi-ish, will result in beneficial boost (increase in psi = decrease in egt).
Will the 2cm decrease in housing cross section be restrictive enough (at 200hp and roughly 1800 rpm) to cause high egts? Not even close. A 450hp truck, full throttle, at 2700 rpm saw the same or lower egts by switching to the 12cm housing. That's the beauty of a small housing and a good wastegate.
Len is looking for mid-throttle, mid-rpm performance. Switching to a smaller housing will spool the turbo harder mid-throttle and will increase the air charge's density, which will decrease egts (providing he stays below 40psi, which isn't a problem with the full wastegate).
I've been in Len's exact same situation before. I added 200hp and my truck pulled worse than with just the EZ. I downsized the exhaust housing and started making boost earlier, where I needed it, and gained back my towing performance. My other example (the mechanic in the cornfield) told me he regularly has customers coming to him after they add an HX40 and wonder where the towing performance went. He tells them to put the stock turbo back on, and whaddaya know, it works every time. No calculators or maps needed on this one. I've been there, done that, hands-on. The guy in the cornfield has done way more research than either of us, and it works for him.
So what, in this post specifically, am I missing?
There's a reason there's test pilots; it's because engineers usually get it wrong on the first couple of attempts. There's no substitute for real world trial and error.
Diesel Freak said:
You can be impressed if you want... I know I am!!!
We can tell...
