Well guys I have finally gotten to give the Mad ECM a try and here are my initial impressions. Now remember that I was very skeptical of the ECM do to what I had read on a few posts.
First off let me say that the bottum end power on the truck was greatly improved over what an Edge EZ provides. Turbo spoolup is greatly increased, this is with running a steroid B-1 which really likes rpm to get it going. Not that the turbo is terrible its just not an HX35. The Mad Ecm really helps in the spoolup dept.
The truck makes more total boost boost than it did prior to the install. On this truck running injectors and an EZ I would make 37-38 lbs. boost, with the addition of the Mad ECM boost is now running in the 42-43 lbs range. The fueling box on the truck was removed for an updated program and should be back on soon so hopefully I will have more data to share.
As I mentioned before I was skeptical and sometimes even downright negative towards the unit. I need to take everything back and tell everyone that if you are looking for a great driving enhancement the Mad ECM would be a great choice.
Doug
Doug
