Mag-Hytec Fluid Levels?
Hi Bob 4X4,
What are your thoughts & have you noticed any problems with the elevated fluid levels that Mag-Hytec recommends?
The "high" mark on the dipstick puts the fluid level at the bottom of the axle shaft. The "low" mark puts the level at just inside the axle tube. And the "plug" in the middle of the ID label, on the back of the cover, puts the level at the factory recommended level.
DC seems pretty serious about what level the fluid should be at.
I think most people are filling to the "high" level to take advantage of the extra fluid capacity.
Are we taking much of a chance for problems by filling to the higher levels?
Have you seen problems associated with over filling the diff's?
A friend, with a Duramax, was told by the GM mechanic that changed his gear oil, that "He's" seen a number of axle failures on trucks with rearend covers that allow higher than recommended fluid levels, and that the stock cover is just fine.
I'd appreciate your thoughts.
Thanks.
Joe F. (Buffalo)
