I've had a Mag Hytec double deep trans pan on my truck for a few years now and it has had a slow leak for almost the whole time. Rather than leak in one spot it weeps around the whole perimeter where the gasket is. I've tried retorqueing it a few times but no luck, it still weeps enough to create slow drips from the bottom fins and coats my skid plate with oil. I used the original fiber gasket, (or cork, not sure), that came with the pan from Genos. I ordered a new gasket from genos in case nothing else works I will reinstall with new gasket.
Anybody else have this problem and if so how did you fix it. Do they make a rubber gasket for this pan. How about RTV, anyone use it on their fiber gasket from Mag Hytec? I think I still have the original Dodge OEM gasket, anybody use the OEM gasket on the Mag Hytec trans pans. Any help would be appreciated, thanks.
