Mag-Hytec DD pan Installation..Concerned
hissing noises
Expert Opinion On My First Oil Analysis
ChiDiesel
Mag-Hytec DD pan Installation..gasket/no gasket
Just got my new MH DD pan... . wow! The installation looked pretty straight forward, but I thought I'd do a search on the board to make sure all bases where covered and no surprises were out there. This is where I got concerned... ..... several folks mentioned a gasket between the VB and the MH filter extension block. None was in the kit that I received. . should there be? Just worried about pulling air in if there isn't a good seal. And anyone know the torque spec's when attaching the block to the VB?
DD Pan
Don't know about those torque specs. but be dammed carefull about the torque spec. on the drain plug----30 INCH! pounds, thats Inch pounds. They can be a bi--h to remove if over tightened. Larry
you do not need a seal. when i did mine i called mag-hytec to be sure. and the mounting surface is nice and flush with the extension block. no worries man,.
Thanks Guys... appreciate the info and I will put a dash of Loctite on the bolts. Nothin' better then real world advice!!!
