Mag-Hytec is a aluminum transmission pan (cover),but requires a rubber or plastic composite gasket not cork as in the stock pan because this is then a aluminum to aluminum contact which is not good ? Corrosin I guess? Anyway where can I locate the best composite gaskets? Thanks !
99-24V-2500-Laramie-SLT-A/T-LSD-355
All Options except cab lights and carpet-Rino- Prime-Loc-Alcoa wheels-Lund cold front-Factory Tows-DSG Electronic Fast Idle-Mag-Hytec transmission Pan+Rear Diff. Cover Tekonsha Voyager VA CPC _ALASKA
