Mag-Hytec Transmission Gaskets
Oil Temperature Gage
Dr.P vs. TST... again
Mag-Hytec is a aluminum transmission pan (cover),but requires a rubber or plastic composite gasket not cork as in the stock pan because this is then a aluminum to aluminum contact which is not good ? Corrosin I guess? Anyway where can I locate the best composite gaskets? Thanks !
99-24V-2500-Laramie-SLT-A/T-LSD-355
All Options except cab lights and carpet-Rino- Prime-Loc-Alcoa wheels-Lund cold front-Factory Tows-DSG Electronic Fast Idle-Mag-Hytec transmission Pan+Rear Diff. Cover Tekonsha Voyager VA CPC _ALASKA
That's interesting...
My Mag-Hytec pan came with a cork gasket and filter from genos garage.
No other mention of special gaskets at all.
keep us posted.
Larry
'98. 5 24V 2500 C. C. SLT, 4X4, Auto, SWB, Forest Gr. /Driftwood, Tow Pkg. , Smittybilt S. S. Nerf Bars, Factory Tow Hooks, K&N, Mag-Hytech transmission,PIAA 1200 Series Fog lights, PIAA Platinum Headlights, Dodge 3 Pc. Bug-Flector,Alpine CDA-855 Head,Alpine VA-100M Sub AMP,Alpine VA-407 4 Ch AMP, Polk Audio (2)6. 5" Components in the doors and (2) Polk 6. 5 Coaxials in back, MTX Dodge RAM Custom Sub Box W/ (2) 10" 5000 series Subs. . 7 7/8 coats of wax. . :D Yes Sir That's My Baby!!
Turbo Terry - According to the Mag-Hytek instructions use Dodge p/n 5012978AA gasket as a replacement.
Gary
'96 2500 extcab, SLT, 4x4, auto-3:54 LSD, Banks#1, Dr. Performance#2, K&N, American wheels, 255/85R16, Bushwacker flares, silence ring & CAT raptured, Rhino Liner, EGT-Boost-Tran temp on dash, Reese class V hitch... Snowmachine hauler (Polaris Baby!)
When I called and ordered the cover I was told to not use cork but I reread the directions and you are right. The one from Dodge is OK it just looks like cork. Well that clears up where I can get gaskets. Thanks for the imfo and time TT
The OE transmission gasket is a cork/neoprene composite.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, PIAA Dual Sport 900 auxiliary lights and Super White bulbs, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Hitco/Geno's exhaust blanket, Femco/Geno's EZ Drain oil pan plug, Banks Stinger 4" dia. stainless steel exhaust system, plus many other trick modifications
Coming Attractions: BD "Medium Stall" TC, BD valve body, BD PressureLoc, BD trick modified front pump assembly, '00 Sport headlights, '00 Sport grille (I'll squeeze it in somehow)
'00 Polaris 6x6
