Engine/Transmission (1998.5 - 2002) MagHytec transmission Pan
How many quarts of transmission fluid do I need to refill after I pull the pan only and install the dbl deep MagHytec transmission Pan or if I evacuate the whole system and install the dbl deep MagHytec transmission Pan?
Thanks BFC
How many total quarts of transmission fluid do I need to refill after I pull the pan only and install the dbl deep MagHytec transmission Pan.
I cannot find the amount of quarts in the owners manual and the dealership said 5 quarts, excluding the 4 for the DD pan
I get between 6 and 9 qts without draining the TC. So if you add another 4 for the double deep pan, you're probably looking at 10-13 qts. The stock TC doesn't have a drain, by the way.
1 of two things. unhook one of the cooler line and flush all of it out or when you have the pan out, loosen up the 10 bolts holding the valve body and it will drain,
Glenn
Depending on what year your truck is the amount changes. I believe in 2001 they started putting a deeper pan on stock. . so it takes a little less... I can not remember for sure.
Back to the top for someone with a copy of the pan directions... .
