hello how is everyone? I’m in the process of rebuilding a 5.9. I got new main bearing cap bolts and installed them with the procedure in the service manual which was 37-44-59-90*. I was looking for the lower water inlet bolt torque spec and I came across someone had posted that procedure is for previously used bolts and stated the procedure for new bolts is 89- loosen completely - 44-63-120*. The second procedure was listed as an 07.5-16 procedure but I believe the bolts are the same. I couldn’t find that anywhere except from the site it was on. (Not here). I think I’m just doing the first one but I was hoping someone could shed some light on this. Thank you.
